Placing volume control on taskbar
Discussion in 'Computers' started by Jon_Are, Oct 13, 2004.
  1. Jon_Are
    Jon_Are Cinematographer
    Jun 25, 2001
    2,036
    Back in the day, my taskbar always displayed the volume control, but somewhere along the way it disappeared. In trying to add it now, I get an error message stating that the volume control is not installed and I need to add it via the add/remove programs section of control panel.
    Of course, there is no such animal listed as volume control under add/remove programs.
    I appreciate any advice,
    Jon
  2. Kelvin Tucker
    Kelvin Tucker Stunt Coordinator
    Sep 17, 1999
    59
    Assuming you have a sound card properly installed, it just depends on which OS you are using.
    For example, under Windows XP it is as simple as -
    Control Panel --> Sounds and Audio Devices --> check box "place volume icon on taskbar"
    K
  3. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    I think you've got a bit of a problem if it says you need to install it via add/remove
    something might have happened to your os installation
    i've never heard of that problem before so I don't really have a suggestion however, sorry.
  4. ThomasC
    ThomasC Lead Actor
    Dec 15, 2001
    6,526
    Try what Kelvin suggested. If that doesn't work, something's wrong.
