Placing the DVD player on top of the receiver (1 Viewer)
Ron_L
Is this a good idea? My component cables I just bought don't quite reach the top of the rack where the DVD player was supposed to go..I was thinking of putting it on top of the receiver. Will this damage anything?
JoeTX
Thats what I've been doing for the same reason for this whole semester and it hasn't done anything yet.
Ron_L
Thanks Joe,
I'm gonna go do that right now.
Do you listen to your music/movies loud?
Michael Reuben
Michael Reuben
Never, ever, place anything on top of a receiver. Receivers generate heat, and heat is one of the greatest enemies of electronic components. You may get away with it for a while, but you're shortening the life of both the player and the receiver.
M.
John Gido
I had a similar problem with placing my DVD player on top of my digital cable box. The cable box generated so much heat that the DVD player started acting up. Brought the DVD player in for service under warranty and was told I had "loose solder joints".
DanaA
Yeah, I too wouldn't place it directly on top of the receiver. The receiver needs to breath. Hopefully, you can find some longer component cables or rearrange things to avoid this. Can you still exchange the cables for longer ones?
Jack Briggs
And probably crush the DVD player, given how flimsily constructed the vast majority of them are.
As Michael and others have said, allow maximum ventilation for a receiver. And that means nothing sitting directly on it.
Michael Reuben
Michael Reuben
what about putting the receiver on top of the dvd player? this would allow the receiver to breathe.
The DVD player has to breathe too. Overheating is a major cause of problems in DVD players.
Ideally, no components should ever be stacked. But no matter what, a receiver or amplifier should never be stacked with another component -- no exceptions.
M.
Vin
That sounds rather insulting, wouldn't you say?! ;)
Seriously though, I kept my DVD player on top of my receiver without a problem......well, for a year and a half anyway,:frowning: at which point my receiver stopped responding to remote commands. After ruling out the obvious (read: the remote) I brought the receiver in for repair (luckily, under warranty). As it turned out it was something as simple as a solder joint that had come loose....quite possibly the result of heat build up.
Vin
JohnnyG
Laser diodes die mostly due to heat and this is the most vunerable part of a DVD player and expensive to replace too. Anything that increases the heat inside the player's case should be avoided.
Ron_L
Thanks guys,
Well I guess I can't do that....
I'll try and move the VCR.
I can't exchange the cables, as they don't except open boxes and i'm not about to throw away $80 and spend an Additional $120.
Thanks Again.
John Garcia
NorCal
Maybe you could try selling the cables on E-bay or audiogon? Or even look for a replacement used one on one of these sites?
neonpizza
