Placing center speaker on t.v.....
Discussion in 'Archived Threads 2001-2004' started by Neal Siva, Nov 9, 2002.
  1. Neal Siva
    Neal Siva Agent
    Jan 20, 2002
    32
    I have a sony 48 inch rear projection t.v. (kp-48s75), the jbl NSP1 package, and two SA-WM40 subs in my setup. I'm placing my n-center on top of the t.v. I'm wondering if the bass from the n-center will damage my t.v. cause of the vibrations? Thanks.
    Here's a link to the t.v. so you can get an idea...
    http://www.newsearching.com/tvs/Sony_KP48S75.html
  2. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    No it won't!
    Even if it's set to "large",I doubt it puts out a lot of bass.
  3. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    TVs are desgned with that type of use in mind. No problem.
    -rob
  4. Neal Siva
    Neal Siva Agent
    Jan 20, 2002
    32
    Aight. Thanks for the help!
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    When playing something loud, put your hand on the TV cabinent. Is it vibrating? While not causing electronic damage, all that vibration is muddying the sound.
    Get some rubber door-wedges, or pink erasers or even paper-back books and use these as feet to get that center off the TV enclosure. Also, pull the center speaker forward so that it over-hangs the face of the TV by about a quarter inch. This will keep the sound from coupleing to the face of the TV.
    Hope this helps.
  6. Lewis Besze
    Jul 28, 1999
    3,134
    I agree,I use Lovan's "The Director" center speaker stand.
    Click on the "little house icon" to see it.
  7. Matt Odegard
    Matt Odegard Stunt Coordinator
    Nov 5, 2002
    212
    Heh Lewis, I see you have a JL Audio sub their. Where did you get the idea to use that for your home sub? How does it sound? Just curious, I own 2 JL W4 15" and love them, probably the best car sub out their as far as I'm concerned. Although I only use 1 in my car as 1 is loud enough.
  8. Mike_Ch
    Mike_Ch Stunt Coordinator
    Nov 26, 2001
    246
    As well as those tweaks that Bob mentioned, I found that putting a large mat of .75 inch wool under the speaker improved the sound even more than the little isolators I use. Also decreased vibrations going into the tv. Be careful not to bolck the ventilation holes though.
    Cheers,
    Mike
