Placement of right surround speaker
Discussion in 'Home Theater Projects' started by Ronneil Camara, Nov 27, 2003.
  1. Ronneil Camara
    Ronneil Camara Stunt Coordinator
    Dec 2, 2002
    235
    I have a .jpg screenshot of my basement but I can't paste URL here since I havent posted more than 15 times here. How would I show it to you so that you can give me an idea on how I can mount my right surround speaker. Thanks.
    Neil
  2. Ronneil Camara
    Dec 2, 2002
    235
    Let me try this link,
    h t t p : / / r e s t r i c t e d . d y n d n s . o r g/ h t . j p g
    If I am able to post it, just remove all the spaces and you'll be able to retrieve the screenshot.
    Neil
  3. Ronneil Camara
    Dec 2, 2002
    235
    Hi guys. Here is a much more detailed information about my basement which also includes the dimensions. The Surround Right(SR wire), Surround Left(SL wire), Front Left(FL wire) and Front Right(FR wire) labels on the basement.gif file is an existing wiring which the previous owner of my house installed. I also have a 320 degrees screenshot of my basement, basement.jpg. And on this screenshot, you will see the existing wires.which I labeled on the .gif file. So, I need some inputs on where to put my 5.1 speakers and how it is to be mounted, either on the drywall or steel stand. Thanks in advance.
    Here are the screenshots on my website:
    restricted.dyndns.org/basement.gif and restricted.dyndns.org/basement.jpg
