arunVB
- Jun 16, 2005
I just purchased a CLR3000 Center channel speaker and am undecided about its placement. My TV stand is a wooden TV Stand (Make : Salamander Designs). My stand is the same as the one in the following link, except that the middle shelves are wider : pg.photos.yahoo.com/ph/arunvb/detail?.dir=/849b&.dnm=bf0d.jpg&.src=ph
I have a few of questions :
1. Which is the best position - above the the TV or in the top open shelf (40" wide x 20" depth x height ajustable from 9" to a max of 18") of my wooden TV Stand, with a insulating base under the speaker.
2. I prefer to keep it inside the TV stand, but I am concerned about the reflections from the wooden interiors of the stand. The shelf is open in the front. Does the reflection, if any, change / reduce the sound stage and is it noticeable ?
3. By default, the shelf is open in the front, but I would like close it with doors. Does this affect the sound quality of the speaker ? The material choices, for the door, are wooden frame with a perforated steel panel or wooden frame with frosted glass panel. If perforated steel or frosted glass is not good, are there any other materials you suggest ?
3. If it is OK to keep inside the stand, since the CLR 3000 has a sub-woofer on its top, how much of clearance do I need from the top of the speaker and the ceiling of the shelf ?
I would really appreciate, if you could help me on this.
Arun
Arun
