Scott Stephens
- Dec 23, 1999
I recently got a new TV (32") and now when I place the center channel on top of the TV, it is about 2 1/2 feet higher than the L/R front speakers.
Is this going to result in an off-axis sound dispersion? Do I need to try to place the center channel as close to the same height as the L/R fronts?
I bought some wood at home depot and was going to make a box that would house the center channel--the TV would then be set on top of that box. This would put the center channel as close the same height as the L/R's as I would be able to, but is it worth it? I'm no master carpenter, and the TV is a fairly heavy one (108 lbs). The last thing I need is a crushed center channel.
But, if it's going to make a marked improvement in my sound dispersion, I'm willing to try. Any thoughts?
Thanks...
Thanks...
