Pixelation Issue
Discussion in 'Displays' started by Tod Golden, Feb 9, 2006.
  1. Tod Golden
    Tod Golden Stunt Coordinator
    May 3, 2003
    82
    While watching the Grammys I would get some pixelation during performances that used strobes or any quickly flashing lights. I have noticed this while watching other shows as well, specifically with HD feeds. Basically, it looks like the screen is filled with a bunch of squares.
    I have a Comcast HD box connected to my Mits WS65613 via component using the cables that Comcast supplied. What steps can I take to resolve this issue, or is it just an inherent problem with CRT based sets?
    Any input would be greatly appreciated.
    Tod
  2. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Compression artifacts probably.
  3. Jon_Liu
    Jon_Liu Stunt Coordinator
    Jul 26, 2002
    211
    that's most certainly what it is. It just means they didn't provide enough bandwidth for the amount of information that was needed. For the most part it should be a problem, it's just when there's fast moving motion that it makes more of an issue.
  4. Tod Golden
    May 3, 2003
    82
    Thanks for the responses. After doing a little research I would have to agree its compression artifacts.
    Thanks again - Tod
