PIP and Dishnetwork
Discussion in 'Archived Threads 2001-2004' started by ArnaudP, Nov 10, 2001.
  1. ArnaudP
    ArnaudP Stunt Coordinator
    Jul 27, 2001
    103
    I need some help with PIP when using Dishnetwork. I have a new Sony Wega with 2tuners for PIP but I can't get it to work. The user manual is not helpful. If anynone uses PIP with Dishnetwork, please explain what I need to do.
    Thank you
  2. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    You need a second sat tuner to tune two different channels to feed to a PIP set. If you also have a cable feed or OA antenna then either one of these could be used to feed the second signal.
    Pete
