Pioneer vsx811
Discussion in 'Archived Threads 2001-2004' started by ChadLB, Dec 31, 2002.
  1. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I currently use this receiver and have a question with my current setup. Since the lowest setting is 100hz is it best to have my main front speakers set to large or small?
    PIONEER VSX-D811S
    EQUALIZER KENWOOD 1070EK
    DVD PLAYER PIONEER DV-333
    TV TOSHIBA 36A40
    VCR SONY SLV695HV
    CENTER CHANNEL ACOUSTIC RESEARCH AR-4C
    BOOKSHELF ACOUSTIC RESEARCH AR-17
    MAIN SPEAKER ACOUSTIC RESEARCH AR-11
    SUBWOOFER ACOUSTIC RESEARCH AR-S112PS
    The specs on the arll's are as follow:
    The AR11 has an 8" side-firing high excursion woofer; a 1" plasma transferred; diamond hardened Titanium dome tweeter and a 5-1/4" Magalloy Minocqua mid-range.
    All transducers are magnetically shielded.
    Driver Complement Plasma Transferred Diamond Hardened 1" Titanium Dome Tweeter; 8" Side-firing High Excursion Woofer; 5 1/4" MagAlloy Monocoque Mid-Range
    Enclosure Design
    Frequency Response 35Hz-23KHz 2dB
    Sensitivity 91dB @ 2.83 Volts/Meter
    Crossover Frequency 100Hz and 3.2KHz
    Rated System Power See Recommended Amp. Power
    Recommended Amp. Power 20 Watts 200 Watts
    Nominal Impedance 8 Ohms
    Enclosure Dimensions 34" x 8 1/16" x 16"
  2. Alf S
    Alf S Producer
    Apr 23, 2000
    3,115
    532
    4,110
    Alfer
    If I were you, I'd let the sub do the low end work instead of those 8" woofers...Set the 811 to SMALL.
    Alfer
  3. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Get this the other day I was in Radio Shack and saw a RCA receiver that was identical to the Pioneer 711/811...that makes me sick......what is going on with that. It makes me want to return my 811....[​IMG]
  4. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
  5. Rick_FL
    Rick_FL Stunt Coordinator
    Dec 4, 2002
    171
    well, atleast is says RCA and not Tandy. Then you'd be really pissed.
  6. Alf S
    Alf S Producer
    Apr 23, 2000
    3,115
    532
    4,110
    Alfer
  7. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    The Radioshack reciever is 5.1 while the 811 is 6.1 the 811 probably has more additional features than just the extra channel.
  8. Mike_HT
    Mike_HT Agent
    Dec 8, 2002
    28
    "Preouts for subwoofer, center-channel"
    Wouldn't have worked for me over the 811 [​IMG]
