sidburyjr
TV: Panasonic Viera P60ST60
Speakers: Magneplanar MG2A left and right channel, some small inexpensive KLH speakers for the rear and the center channel.
Receiver: Pioneer SC-1222-K
Inputs: Comcast HDDVR, Apple TV (version 1), PS3
Receiver is connected to the TV via the HDMI-2 connector which is the ARC channel. All inputs are connected to the Receiver via HDMI cables.
When I run Apple TV or PS3 (as a Blu-ray or CD player) things work fine.
When I run my cable the following has been happening regularly: When I change channels the set goes blank, and in a short time (5 seconds or so) the new channel comes on usually fine. Occasionally the video goes bonkers for a short while (5-10 seconds) bonkers = incorrect colors (as if the RGBs were switched) OR nothing but snow OR other weird things. There is no sound when the channel is changing.
Starting yesterday on a large number of our channels several times per minute the screen would go black but the sound would continue, then the picture would come back.
I have swapped HDMI cables for the HDDVR to the Receiver. No improvement.
I have connected the HDMI cable from the HDDVR to a different input on the receiver. No improvement.
At the moment I solved my problem by connecting my comcast box directly to the TV through one of the TV HDMI connectors and my receiver connected through one of the others. The (cable )TV works fine with this as do the Apple TV and PS3 hooked through the receiver which is connected to the TV
When I moved, I lost my receiver manual so it's possible that I have not configured my receiver setup correctly.
Any suggestions as to how to proceed would be greatly appreciated.
Dick
Dick
