Pioneer Elite Pro530HDi Question
Discussion in 'Displays' started by Keith Hancock, Feb 18, 2004.
  1. Keith Hancock
    Nov 25, 2003
    15
    Hello,
    I recently purchased one of Pioneer's Elite Pro 530HDi models. The set has some "blue bleed" along the bottom of the picture, ie; on white scenes some portions of the picture appear blue.
    I plan to have the set "ISF'd" in late august,will that fix the problem or do I have a bad set?
    Thanks for everyones help.
    Regards
    Keith
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,373
    32
    New England
    Gregg Loewen
    Sounds like simple convergence error of the blue gun. You can correct this in the user menu, under convergence settings. HD and DVD will have to be done separately. If this doenst help then your guns will have to focused. Make sure you inquire about focus work (mechanical and electronic) by the ISF you employ. Not all ISF techs will do this.
    Best wishes
    gregg
  3. Keith Hancock
    Nov 25, 2003
    15
    Hi Gregg,
    I have performed both Multipoint convergence's for HD and DVD settings.. I'll try again this weekend when I have a few hours..
    Michael Chen will be visiting the Northwest in late August,hopefully he will be able to help..
    Thanks for your help.
    Keith
