Pioneer Elite DV-F07 & Klipsh Reference Series RP-3 & RC-3 for sale.
Discussion in 'Archived Threads 2001-2004' started by Robert_eb, Nov 22, 2001.
  1. Robert_eb
    Robert_eb Supporting Actor
    Sep 14, 2001
    965
    I have for sale a 301 disc DVD changer (PIONEER ELITE DV-F07 MSRP $1250.00) and also my front three speakers from Klipsch (RP-3 AND RC-3). The speakers are less than 8 months old and harldily ever used. The DVD player is a little over a year old and is in like new condition. Here are the specs for the speakers. RC-3: FREQUENCY RESPONSE: 62Hz-20kHz±3dB SENSITIVITY: 97dB @ 1watt/1meter POWER HANDLING: 150 watts maximum continuous (400 watts peak) NOMINAL IMPEDANCE: 8 ohms ENCLOSURE TYPE: Sealed DRIVE COMPONENTS: Two-way system using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a 6" (15.24cm) square 90° x 60° Tractrix® Horn and two 6.5" (16.5cm) magnetically shielded, aluminum cone woofers TWEETER: K-105-KV 1" (2.54cm) Titanium dome compression driver HIGH FREQUENCY HORN: 6" square 90° x 60° Tractrix® Horn HIGH FREQUENCY CROSSOVER: 1950Hz WOOFER: Two K-1085-SV 6.5" (16.51cm) Cerametallic® cone / cast polymer frame DIMENSIONS (H x W x D): 7.9" (20.1cm) x 22.9" (58.2cm) x 9" (22.8cm) WEIGHT: 29 lbs. (13.18kg) ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF) FINISHES: Matte-finish Black vinyl. RP-3: FREQUENCY RESPONSE: 27Hz-20kHz±3dB SENSITIVITY: 95dB @ 1watt/1meter POWER HANDLING: 110 watts maximum continuous (300 watts peak) NOMINAL IMPEDANCE: 8 ohms ENCLOSURE TYPE: Sealed DRIVE COMPONENTS: Three-way sytem using one 1" (2.54cm) magnetically shielded, titanium dome compression driver tweeter with a 6" (15.24cm) square 90°x60° Tractrix Horn, one 6.5" (16.5cm) magnetically shielded, aluminum cone midBass driver and one 10" (25.4cm) side-firing, fiber-composite cone subwoofer TWEETER: K-105-K 1" (2.54cm) Titanium dome compression driver HIGH FREQUENCY HORN: 6" square 90°x60° Tractrix Horn HIGH FREQUENCY CROSSOVER: 2750Hz MIDRANGE: K-1081-S 6.5" (16.51cm) Aluminum cone / cast polymer frame MID-FREQUENCY CROSSOVER: Fixed at 90Hz SUBWOOFER: K-1082-K 10" (25.4cm) Fiber-composite cone SUBWOOFER AMPLIFIER: Peak output power 440 watts into 4 ohms DIMENSIONS (H x W x D): 40.5" (102.9cm) x 9" (22.9cm) x 16.8" (42.7cm) WEIGHT: 62 lbs. (each) (28.2kg) ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF) FINISHES: Black ash vinyl veneer. I'm asking $899.99 for the dvd player, $799.99 for the RP-3s and $199.99 for the RC-3. I will take best offer. I have all original packaging.
  2. Robert_eb
    Sep 14, 2001
    965
    I'm still selling the Klipsh speakers. I've droped my price to $499.00 for the RP-3 and $175.00 for the RC-3.
