Pioneer Elite DV-47Ai questions!
Discussion in 'Archived Threads 2001-2004' started by BrianSmith, Jan 18, 2003.
  1. BrianSmith
    BrianSmith Stunt Coordinator
    Jan 8, 2003
    58
    I am thinking of purchasing the DV-47ai and the 49TXi receiver.
    Does the receiver come w/ the "i-link" cable? Do I need to buy a regular digital coax cable?
    Also, when listening to standard CDs I assume the MCACC calbiration will work w/ the signal. Am I correct?
    If I were to buy another brand DVD player and use the coax digital out I assume I would still be able to use the MCACC function.
    Help greatly appreciated!
    Brian Smith
  2. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Brian- I think I can answer 3 of 4...
    I-link cable with either the receiver or player? Not the player (I have one, and not there.)
    Would you need to buy a regular coax cable: probably not. *If* std DD/DTS signals can also be sent via the I-link cable.
    CDs and MCACC: I would hope so! [​IMG]
    Different brand DVD player and MCACC: yes.
  3. Ron Newsome
    Ron Newsome Stunt Coordinator
    Oct 27, 2000
    52
    Brian, the i-Link cable does come with the 47Ai and that's the only cable you need when paired with the 49TXi. You do not need an optical/coax cable. I-Link passes everything except video.
    MCACC works with all audio inputs.
    Sound & Vision did a review of the Pioneer combo in the February/March issue. It starts on page 69.
  4. Sach
    Sach Stunt Coordinator
    Aug 25, 2002
    70
    Yup Brian, Check out the 47Ai - 49Txi combo review in the latest Sound and Vision!
    the review is exclusively about the ilink connection.
  5. BrianSmith
    Jan 8, 2003
    58
    Thanks guys!
    Unfortunately I placed an order for a $100 digital cable first!
    I live in a town that doesn't carry S&V. Argh. Don't suppose someone would fax it to me? ;-)
    I'll see if I can order it directly.
    -Brian
  6. Kevin C Brown
    Aug 3, 2000
    5,712
    Brian- Sorry about. :b The 47ai does come with the i-link cable. I just didn't remember it. Well, the cable you get with the player can't be worth much more than $10 or $15, so if you really did spend $100, probably a lot higher quality anyway...
  7. BrianSmith
    Jan 8, 2003
    58
    Actually, the $100 cable won't work because it is not an i-link cable. I assume the i-link connection does not use an RCA cable.
  8. Ron Newsome
    Oct 27, 2000
    52
    Brian, return that cable and get your money back! The i-Link cable that comes with the 47Ai works just fine and there is no reason to replace it, unless you need a longer length.
