Pioneer Elite DV-47Ai hack help needed
Discussion in 'DVD' started by Tony Casler, Aug 21, 2003.
  1. Tony Casler
    Tony Casler Agent
    Apr 13, 2003
    43
    Does anyone know how I can region mod this player? I can't find any help on the web, and I really don't want to buy a cheap, crappy player for non-US discs.
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    You'll need a mod chip, and someone to install it. Total cost (which probably includes shipping your deck to Europe) will be $200 or so including labor.
    I suggest you buy a Malata
  3. Tony Casler
    Tony Casler Agent
    Apr 13, 2003
    43
    Why Europe? Is there any place in the US that will do it, or could I just buy a chip and do it myself? I'm very competent with a soldering iron.
  4. Jeff Kleist
    Dec 4, 1999
    11,267
  5. Jim Blackie
    Jim Blackie Stunt Coordinator
    Apr 3, 2001
    110
    Pick up a Toshiba 3900. Slip in any Region disc, hit Top Menu, 1, Play and it will start. Clear the warning message by pressing Marker, Clear.
    Vyola, as the French almost say. Costs under $100. Great little machine.
  6. RobD
    RobD Second Unit
    Jan 21, 2003
    264
    Ive used these guys in the UK and they used to mod US players too (DV-47AI is pretty much a DV-757AI). They may also be able to sort out PAL Progressive scan for you too (If thats important).
    Link: http://www.techtronics.com
    As far as I know multiregion for that player can be done with a hacked firmware as the DV-757AI can be.
    Also try here: http://www.jvb.nl/
