Richie-C
- Jun 7, 2002
Trying to find out if anybody else out there is running the 49tx with Paradigm Studio 100 speakers and if so are they having any issues with the 49tx shutting down at high volumes.
That is my set-up and I am experiencing shutdown's at -13 with the fronts set at large and at -8 witht the speakers set to all small. My center is a LCR450 paradigm and my surrounds are paradigm Studio ADP's.
Paradigm says they are compatible with 8 ohm speakers but I don't know what that means. I am trying to find out the spec's for the paradigm speakers from paradigm. The 49tx states that it is to be used with 8 ohm speakers.
Any information or help would be appreciated.
Rich
Rich
