dealy
- May 11, 2003
Hi,
I recently inherited a Pioneer D703 LD player and 31 LDs (includint the SW trilogy, yea!). Unfortunately it required some repairs to get working properly which cost a bunch of money. Now I want to maximize what I'm getting out of this machine.
I've been getting conflicting reports about which outputs I should be using in my system. I would like to hear your opinions about the appropriate ones.
I have a Toshiba TW56x81 widescreen tv, which looks pretty great with my DVD player. It has options for composite, s-video and component video inputs.
My A/V receiver is a B&K AVR 202 (I think). A year 2000 model w/105 watts x 5 channels and no component video switching, but it can handle everything else.
I also have a simca A/V switch that can handle 2 channel audio, s-video and composite video switching between 4 sources.
I've never been happy running s-video through the B&K so currently I have a high quality s-video cable running from my s-vhs vcr directly to the tv, this will have to change when I add the LD player if I use s-video.
I've had some people say I should be using the composite out from the D703, but the guy repairing the unit now says I should use the s-video out. Any complete and well thought out reasons why I should prefer one over the other? I don't particularly want to go through the hassle of buying both types of cables and returning one. I'll most likely be using bettercables, as I've been happy with them before.
From a convenience perspective I'd prefer s-video, since I'd only have to buy 2 1 meter cables (for the vcr and LD to which ever switch I choose) as opposed to buying a 10' long composite cable to run to the TV.
Also what is going to give me the best audio from this D703? The digital coax, toslink or standard 2 channel rca outputs? The unit doesn't output AC3, so I think my B&K can handle the digital out, but I'm not sure. Anyone of you know if that is the case? What do you think the best options are here?
Thank in advance, Derek
[email protected]
[email protected]
