Seth=L
- Jul 17, 2006
- Seth L
I posted on another thread about these and Lance had some suggestions for me, I did what he told me and found nothing new. He suggested that I test each driver individually and I did, found no driver problems. I kept them apart to look at the x-over and I may have found something. I wish I had a digital camera to show you guys, but sadly I don't so I will explain it as best as possible.
The x-over network includes 2 attenuation devices for high frequencies and mid frequencies. There are also 5 capacitors, all different sizes, The largest one has a 50 printed on it and the smallest one has a 2.4 on it. The caps are metalic with both ends having a single soldered wire coming out of the black plastic end.
What troubles me is the smallest one has only one end that is plastic while the other end is open with no wire attached. There is another wire that is open ended. My question is should that open ended wire be connected to the capacitor and if so how should it be connected? I know little to nothing when it comes to cross-overs.
When I purchased these speakers they sounded good, but when they were played for only a few minutes my receiver shut down from an overload. It would seem there is a short somewhere or something. I cannot imagine another reason why my transistors would get so hot so quickly.
I am open to any and all info on these speakers even if it does not pertain to the current problem of these speakers i.e. specs if they even exist.
Seth=L
Seth=L
