Pioneer CLDS104 Laserdisc Player $45.00 (1 Viewer)
Steve Blair
No, it has a video out which is what you should be using if you have a tv with a good comb filter. If you use Svideo out then the LD players' comb filter takes over which is almost never as good as your tv's unless you've got a $1000.00 LD player. For most setups the video out is the best way to go. Hope this helps!
MusicLover95
