Pioneer CLD-D704 Laserdisc player, Do I need a Demod for DD, AC-3?
Discussion in 'Archived Threads 2001-2004' started by todbnla, Nov 22, 2002.
  1. todbnla
    todbnla Screenwriter
    Oct 17, 1999
    1,514
    39466
    Todd
    I have a chance to buy a Pioneer CLD D704 Player. If I do so do I still need a Demodulator to play discs with DD 5.1, AC-3 sound? Yes or No?
    PLMK-Thanks
  2. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    110
    Yes, you will need a demodulator. You will connect the AC3 out on the LD player to the demodulator, and then go from the demod to your reciever by a digital cable.
  3. Wilson W
    Wilson W Agent
    Sep 7, 2002
    37
    No, 704 has a digital output.
    In fact, I was just using that a moment ago. Older model, however, may need one.
  4. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    110
    Wilson,
    LD dolby digital (AC3) cannot be passed through the digital output. Dolby digital on LD is stored on the right analog track and is stored in RF form. On the back of the 704 there is a specific output for AC3. The output is in RF form, and must be passed through a demodulator for conversion to digital. The digital output on the LD cannot be used to pass RF AC3. The digital output can be used for DTS and PCM and can go directly into a digital input on the reciever.
  5. Wilson W
    Wilson W Agent
    Sep 7, 2002
    37
    ah, I forgot my receiver has an AC-3 input.
    thanks for the correction
  6. todbnla
    Oct 17, 1999
    1,514
    39466
    Todd
    Ok, gents, thanks!
  7. There are 3 outputs on the back of the CLD-D704. There is an RF-Digital coax (this is your DD AC-3) this connects to a modulator to get DD 5.1. Then there is a coax and an optical digital out which passes either PCM Stereo, Dolby Pro Logic, or DTS depending on the disc.
  8. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Dont forget Mr Analog!
    The occasional old disc without Digital, (I found that out on Back to the Future a while back)and the occasional Directors commentary on an analog channel.
  9. IraSWeiss
    IraSWeiss Stunt Coordinator
    Dec 1, 2001
    57
    It's really unfortunate that on their DVD/LD players Pioneer did not demodulate the Laserdisc RF signal and send it to the optical and coaxial outputs. Who needs two wires?
  10. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Todd,
    In case you're confused....
    You will need a demodulator to listen to Dolby Digital AC-3 tracks only.
    All Dolby Digital LaserDiscs will also have a PCM stereo track that you will be able to use through eithher the analog or digital output. This will be derived for ProLogic and will sound great.
    If you don't have a lot of AC-3 discs I would suggest not bothering with a demodulator. The PCM sound will not dissapoint you.
  11. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
  12. Rachael B
    Rachael B Producer
    Jun 5, 2000
    4,709
    32
    1,610
    Knocksville, TN
    Rachael Bellomy
    Demodulating in an LD player is impractical because it would be difficult to shield the other parts from the RF field. The only LD player ever with onboard RF deodulation was the MSB Silver and it's demodulator was mounted in a little box on the back panel.
