Pioneer 1014, what settings do you use?
Discussion in 'AV Receivers' started by james_stewart, May 22, 2005.
  1. james_stewart
    May 15, 2005
    33
    What settings do you use on Pioneer 1014 for:
    Music CDs- I use Stereo
    Movies-I push the standard button until i find one i like
    TV watching-I use Dolby Digital
    Gaming-I use dolby digital
    What do you guys use?
    ~james
  2. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    gaming: depends on the game, usually prologic.
    music : stereo but the 1014 IMO is kinda crappy at stereo music
    Movies: if its a THX movie then it goes in thx, if not its usually just a click of the standard button.
  3. chrisCo
    chrisCo Extra
    Dec 24, 2004
    22
    Music CD's- Stereo mostly, sometimes 7 channel stereo depending on the source material.
    Movies, SACD, DVD-A - DTS if available is always my first preference. If not whatever auto surround selects is generally fine. I find the advanced effects gimmicky. Not alot of THX listening so far.
    TV - when a true Dolby Digital signal is present that usually works well, I get very little of that from Dish Network. The generic TV stereo which dish provides for 95% of their programming sounds unimpressive no matter what I select, very disappointing.
    Games - N/A
  4. Sam Pat
    Sam Pat Stunt Coordinator
    Jun 15, 2003
    118
    Movies - Auto Standard.
    Music - Usually Stereo, sometimes PLII.
    Games - Usually from XBOX DD5.1, so Auto Standard again.
    BTW, I just got this receiver and I noticed that everytime a new source comes on, it flashes a "Normal +4" message or something. Actually, maybe even "Normal Dialog +4".
    I am sure I dont have any enchancements/ modifiers on.
    Any idea what that message means?
  5. Chuck_W
    Chuck_W Second Unit
    Dec 7, 2003
    397
    CD's - "Direct" mode. Sounds best hooked up with an analog connection from CD player.
    Movies - Either Standard (DD or DTS) or THX DD/DTS depending on the movie or which EQ setting I'm using.
    TV - 7 Channel Stereo
