Pioneer 1014 or 45TX?
Discussion in 'AV Receivers' started by PeterStrong, Oct 3, 2005.
  1. PeterStrong
    PeterStrong Auditioning
    Mar 26, 2004
    11
    Hi everybody -
    I've got the chance to pick up an Elite 45TX for $375 or so locally. I was wondering if this is worth the little bit extra or if I should keep looking for a 1014 on ebay or around here. The specs are so similar that I'm not really sure which way to go. I know the 1014 has PLIIx, and the 45TX is rated for 10 wpc less, but was wondering if anyone can add some real-world advice.
    Thanks in advance -Peter
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I'd go with the 45Tx. The 1014 is basically the same as one model below the 45.
  3. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Both are great receivers. The 45TX is going to have a slightly better build quality and perhaps a small amount more power. The 1014TX is going to have newer features like PLIIx and Component Video transcoding. I replaced a 43TX w/ a 1014TX mainly for the benefit of Auto-MCACC and didn't feel like it was a step down at all. That said, if you don't need the component video transcoding then i'd probably go w/ the 45TX.
