perryG
- Feb 1, 2005
I just got a 1014 a few days ago and so far I really like it. Trying to figure out all the settings and what they do etc. I did the Auto MCACC thing and that worked ok but I can't seem to figure out how to tweak things. Every time I go in and want to change something it wants to play tones or something. I just want to tweak what is there not recalibrate everything. I have 7 speakers and no sub. The center,L&Rfronts and L&R surrounds are set to large and the small back speakers are set to small. Most of the sound was coming out of the front speakers so I want to crank up the side speakers and the rear speakers to get a little more Surround effect. I was able to crank the side speakers using the Effect/CH Select button on the remote. So where are these bias settings created and how do you set them back to default values? They were not zero before I messed with them. I raised the side speakers settings from 6 to 10db and that helped a lot. The rears were already maxed out at 10db in the default settings so I guess I can lower the front speaker volume and raise the side and rear values. I would like to boost the bass on the front speakers also since I have no sub. They do have 12" woofers so they do pretty well on the low end. I am still confused at haveing two different places to change relative speaker volume.
Perry
Perry
