Pioneer 1014 enough for B&W?
Discussion in 'AV Receivers' started by Scott Andrew, Dec 13, 2005.
  1. Scott Andrew
    Scott Andrew Stunt Coordinator
    Nov 9, 2004
    63
    I currently have a Pioneer 1014TX receiver with Athena speakers and a Dayton sub. I just purchased (yet to receive) B&W DM604-S3 front towers, B&W DM602-S3 rear surrounds, B&W LCR600-S3 centre channel and an HSU STF-3 Subwoofer... now my question is will the Pioneer Receiver be enough to power these speakers??
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I'd say look for at least a 2ch amp for the mains.
  3. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    I disagree with John. If you run them at "small" and crossover at 60-80Hz, which you should do with an SVS sub, the Pioneer should be 100% fine. Try it and if there's a problem you can add an amp later.
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    If you want to run them large.. I'd find a two channel amp. [​IMG]
  5. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Even in 2ch full range I don't think the 600 series would expose any major flaws in the 1014's amplification. The 700s or 800s would be a completely different story.
  6. John S
    John S Producer
    Nov 4, 2003
    5,460
    Depends on how loud one likes to listen I suppose.
    The 1014 just did not cut it in my room at all even with the corss over to sub set much higher than I like it to be. But I watch movies at true reference levels often.
  7. Stephen Hopkins
    Jul 19, 2002
    2,598
    Reference level isn't a problem for my 1014TX in a 18 x 28 room w/ Swans 4.1 mains (6ohm, not easy to drive), 2.1 surrounds, Avalanche sub.
