Pioneer 1014 and Videogames
Discussion in 'AV Receivers' started by KerryKimball, Mar 8, 2005.
  1. KerryKimball
    KerryKimball Auditioning
    Feb 17, 2005
    12
    If I'm playing a Gamecube game encoded in Dolby Pro LogicII (using analog stereo cable through the front panel) Should the Dobly Pro Logic light up on the OSD?? Not sure it does... and if it doesn't and I'm manually switching to Dolby Pro LogicIIx Cinema (with the Game mode on) am I "losing" the encoded 5 channels OR is it basically the same with stereo forced through that matrix??
    Haven't tried with PS/2 yet but I'll use optical for that..
    Thanks for the help
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    No digital connection aye?
    Most decoders, can't really tell what is comming in over the 2 channel L/R/ cables. You generally have to select the sound mode of your choice for it. DPLII is default on many decoders, but certainly not all of them.
  3. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    Just change it, Sometimes the signal will be recognized but othertimes not. Just turn it on. Make sure you have it enabled in the game, as Dolby surround is not usually the default sound setting
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Pro Logic and PLII are stereo, not 5ch. Check the specs for the game, as not all sequences may be in PLII, as I've seen some other games do this - actual gameplay is stereo, while the cut scenes were multichannel.
    ALL Dolby decoders should pick up Dolby Surround encoding when set to "Auto".
  5. Ryan Leemhuis
    Oct 1, 2002
    490
    If it is marked on the boc as PLII it will have a surround option. I guarantee it. Which game is it? I might have it
  6. KerryKimball
    Feb 17, 2005
    12
    Figured it out
    It's Resident Evil 4 and it is AWESOME, by the way
    If you don't have it
    get it.
  7. Ryan Leemhuis
    Oct 1, 2002
    490
    I've beaten EVERYTHING in the game [​IMG]. Just go to sound options and select dolby surround. Set your receiver to pro logic II and you are set
