Pioneer 1014 and Videogames
Discussion in 'Gaming' started by KerryKimball, Mar 8, 2005.
  1. KerryKimball
    KerryKimball Auditioning
    Feb 17, 2005
    12
    If I'm playing a Gamecube game encoded in Dolby Pro LogicII (using analog stereo cable through the front panel) Should the Dobly Pro Logic light up on the OSD?? Not sure it does... and if it doesn't and I'm manually switching to Dolby Pro LogicIIx Cinema (with the Game mode on) am I "losing" the encoded 5 channels OR is it basically the same with stereo forced through that matrix??
    Haven't tried with PS/2 yet but I'll use optical for that..
    Thanks for the help
  2. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
    there are only 2 channels, the rest are simulated. the gamecube is only capable of stereo sound, but if you put your receiver in DPLII mode, you will be taking advantage of what the game designers had in mind. DPLII usually sounds pretty good to me when a game is designed that way. put your receiver in II or IIx mode, and you should be all set.
    CJ
