Pio VSX- D814K
Discussion in 'AV Receivers' started by DavidStaggs, Feb 19, 2005.
  1. DavidStaggs
    DavidStaggs Auditioning
    Feb 13, 2005
    12
    Ok, this is my first post but I have looked over some of the forum and i see that people keep saying go for the 1014 from pioneer. Is there anything wrong with the 814 and i should go spend some more, or is this receiver worth savig $150?
    I dont even have to say this, but please let me know the brutal truth [​IMG]
    David
  2. gene c
    gene c Producer
    Aug 5, 2003
    5,849
    49
    Bay area, Ca
    Gene
    It's not so much that there is anything wrong with the 814, though I'm sure there is, it's just that the 1014 is so much better. If you get the 814, you will be itching to upgrade before you know it. The 1014 will be on your rack for a long time. Do it right the first time. Get the 1014. It's second on my "to do" list. A better dvd player is next for me though.
