Pics of my humble HT
Discussion in 'Home Theater Projects' started by Stewart.D, Jan 2, 2004.
  1. Stewart.D
    Stewart.D Auditioning
    Jan 1, 2004
    4
    This is my first post so forgive me if the format is not 100%.
    I’ve been a reader of this site for over 2 years and have picked up numerous ideas (i.e. How to create an arc for a stage using 2 nails and a piece of string) that I put into action over the holidays. My folks came into town for Xmas so I decided to put my Dad to work…(far more talented than I when it comes to construction).
    Background: We purchased our house 2 years ago (a builders spec home) and had the basement finished at that time. Along with a friend I wired the basement and simply ran speaker cable to the back walls. The layout is rather basic – one large room that is used as both a rec room and a HT. The walls were painted an off-white.
    Upgrades over the holidays: We started on Dec 26th and finished on Dec 31st. Upgrades include – New paint (Dark Blue), Front Stage and Feature Wall.
    Again, thanks to everyone for the ideas and appreciate any comments you might have.
    I'm not able to imbed a URL so see my homepage setting for the pics.
  2. Parker Clack
    Jun 30, 1997
    12,216
    59
    9,110
    Kansas City, MO
    Parker
    Stewart:
    What is type in the url to your homepage without the http or the www in front of it. When I click on the link that you have associated with your profile it takes me to your yahoo page but doesn't allow you to view the pictures.
    Parker
  3. Stewart.D
    Jan 1, 2004
    4
    Thanks for the head's up Parker...the home page link should now show my pictures. Sorry.
  4. RAF
    RAF Lead Actor
    7,061
    Very nice!
  5. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,412
    312
    9,110
    Cees Alons
    (Here's Stewart's link)
    Stewart,
    Only 5 days? Great! Can you tell us a bit more about the dimensions, etc.? Please! [​IMG]
    Cees
  6. Stewart.D
    Jan 1, 2004
    4
    The room is essentially a rectangle...roughly 26ft long X 14ft wide. The HT used area is 14ft long by 14ft wide.
    The stage is approx 4 X 8 (4ft at its deepest) & is constructed out of a 2x10 base with a 3/8 MDF top.
    To cover the stage I wanted a dark carpet, either black or dark grey. A local carpet store had the perfect material - black with a rubber back but they wanted $5/sq ft. I found the same carpet material @ Home Depot that was cut into 3x4 matts...purchased 3 for $30 total.
    BTW, does anyone know how to take wood glue out of berber carpet???
  7. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    What color is the room?
  8. Stewart.D
    Jan 1, 2004
    4
    It's dark blue. The color is called "Distance" - Behr Paint.
  9. LaMarcus
    LaMarcus Screenwriter
    Mar 7, 2002
    1,619
    Very nice man, I love the stage you made for the RPTV. You might consider raising your center channel just a bit, so that it can be closer to ear level. At any rate, very nice.
