Jon_H
- Feb 22, 2000
well, I am finally done, over a month of contructing because of finding time to work on it. I am very pleased how it turned out, sounds amazing, just need to run a few tests on it.
A few questions, is there anyway and can actually test the sub to see what its actually tuned to?
Here is the link to the previous thread about my sub:
http://www.hometheaterforum.com/htfo...hreadid=107660
Completed (the edges of the sub dont really look like that in person, must just be the picture, the laminate is a very flush fit cut with a router and a flush trim bit.....(cut my fingers about 10 times on the edges before I filed them a little, they are razor sharp after cutting it.) Oh, and there are spiked on the bottom, dayton audio spikes...i like them
here are links of the building process:
Here is a shot of the dowel job Im doing on the joints (1/4" dowels)
Here is a shot of that same joint Butted together, nice flush fit
Here is a shot of the inner brace put together, (not glued yet, will glue after all dowel holes are drilled)
Here is a close up of the dowel proccess
Here is a shot right before I did my first gluing, all dowels holes cut
Heres a shot of it clamped
Picture 1
Picture 2
Picture 3
Picture 4
http://www.digitalpose.com/mbr/1/113...3514853_vl.jpg
http://www.digitalpose.com/mbr/1/113...7244447_vl.jpg
Hope you guys like...I know I do any feedback or questions would be appreciated. Next task it to heav those BOSE speakers in the dumpster and build some 281's
Im building a cloth speaker grill to go over the entire front as I write this, should be done in a few days and should make it look alot nicer
Picture 1
Picture 2
Picture 3
Picture 4
