Pics of a new set of cables Ive made
Discussion in 'Accessories, Cables, and Remotes' started by David K., Aug 22, 2004.
  1. David K.
    David K. Second Unit
    May 14, 2004
    260
    what do you guys think? These are my newest cables, theyre headed for ebay, hopefully theyll sell more then cost unlike my other cables [​IMG]
    [​IMG]
    [​IMG]
  2. Micah Wells
    Micah Wells Agent
    Oct 21, 2003
    42
    Nice. Can You post the EBay link?
  3. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,412
    312
    9,110
    Cees Alons
  4. David K.
    May 14, 2004
    260
    ya, sorry my intentions were not for advertisement, but for opinions on my custom cables. Thanks for your input [​IMG]
  5. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    Why are there 4 connectors on one side & 8 on the other?
  6. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    My guess is that there so you can bi-wire a speaker with only one amp.
    Those are very nice looking cables btw. The only cable I have made so far is the CAT5 speaker cables. Of course mine look like crap though [​IMG]. What type of cable did you use for the conductor? Is it just standard 12 Ga zip cord or something really fancy?
    Ryan
  7. Bryan.T
    Bryan.T Agent
    Aug 27, 2003
    33
    Those look pretty slick. What kind of banana plugs are those and where did you find them? I have been looking for some decent priced locking ones, but have not had good luck doing so.
    Bryan.T
  8. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    Nice. The breakout looks great. How did you do the transition if you don't mind me asking. It looks a lot claner then your first set.
  9. Brian Fellmeth
    Jul 30, 2000
    789
    I'm not David, but I know where those locking bananas came from. A guy in SoCal sells them on Ebay- search for "locking banana plugs" Quality is so so, but very cheap.
  10. David K.
    May 14, 2004
    260
    ya, brian nailed it on the head,
    regarding materials
    3-1 dual wall adhesive heatshrink finished with 2-1 red heat shrink. Cables used are Canare 4s11.
    thanks for the compliment, I would hope they look a lot cleaner, these are like the 12th pair of cables ive made [​IMG] with each pair, I get cleaner results.
  11. Cam McFarland
    Feb 6, 2004
    699
    LMAO....Of course It would help if i knew what this meant.
  12. David K.
    May 14, 2004
    260
    they are bi wire cables. two go to the amp and 4 to the speakers. the pic shows a pair of them stacked.
  13. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    Isn't that called a "shotgun" cable?
  14. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    There for speakers that have separate crossovers for the woofer and tweeter. You can use two amps one per driver or one amp and one of these cables that splits the signal. Or you can use a little metal jumper at the terminal cup of the speaker [​IMG].
    Ryan
