MichaelDDD
- Sep 29, 2003
- Mike
I've completed the screen for my FP/PJ HT.
I didn't save all my receipts, but total cost (not including time, obviously) was about $120, give or take $10. A comparably-sized, commercially purchased screen can easily run $500 or more. My screen is 95% as good as theirs for 1/5th the price.
I constructed what's called a "Blackout Cloth Screen" (BOC). No, not Blue Oyster Cult.
BOC is used to line light-blocking drapes. There's always one bright side and it has the ideal quality of reflecting light right back out where it came from. Perfect for projecting onto! BOC can be purchased at any fabric/craft store. (Joann's/Hancock Fabric/etc)
After figuring what size screen I needed (44" x 78" for a 16:9 screen), I purchased the materials.
The screen is constructed from 1" x 3" pine boards purchased from Home Depot. The frame around the screen is made of the same boards and covered in black felt.
I was going to use the construction method on this page, but a skilled woodworker buddy suggested using "lap joints." I'm lucky to have access to a woodshop w/lots of good tools, so that's what I did.
Here's what lap joints look like
Photo 1
Here's how they fit together
Photo 2
Here's the dado cut in the middle of the horizontal spars for the brace (you have to brace the frame, else it'll bow/bend when you stretch the BOC cloth over it)
Photo 3
The frame is held together w/wood glue and 3/4" brad nails
Photo 4
Finished frame (the middle support is recessed in b/c I didn't want it touching the screen, but that didn't work out too well - the other side of the frame was used against the cloth)
Photo 5
Blackout cloth laid on top of a sheet so the cloth doesn't get dirty/damaged
Photo 6
Frame on top of BOC (I wound up flipping the frame over, i.e. the side you're looking at in this pic wound up against the BOC)
Photo 7
I stretched and stapled the BOC according to the instructions here and here
Finished screen! (Your fingers will be falling off and an electric staple gun is HIGHLY recommended!)
Photo 8
Now it was time to make the black border. The boarder is optional, but the black frame really raises the perceived black levels on the screen. The frame is just 1" x 3"s sized to fit around the 44x78 screen and cut at 45-degree angles. Black felt (from fabric store) is cut and stapled around the pieces.
The frame pieces are laid around the screen, fitted up, then I used flat L-brackets to bolt the frame pieces together, then I used 3-inch flat iron pieces to join the frame to the screen.
L-bracketed frame
Photo 9
L-bracketed and ready to be joined to screen
Photo 10
Not real pretty from behind
Photo 11
But oh, is it worth the work!!!!
Photo 12
Photo 13
(Admin note = photos turned into links due to file size.)
Photo 1
Photo 2
Photo 3
Photo 4
Photo 5
Photo 6
Photo 7
Photo 8
L-bracketed frame
Photo 9
Photo 10
Photo 11
Photo 12
Photo 13
