Picking up an EQ today. Is there a difference between 90 and 95 s/n ratio. (1 Viewer)
Jerome Grate
Picking up this Audio Source from J and R for 119.00 it has the signal to noise ratio rated at 95dbs as oppose to it's smaller counterpart that has a signal to noise ratio of 90dbs for 89.00. I'm using it for my two DIY subs so stereo isn't the big deal, so will the difference of 5 dbs be that noticeable in my current application.
TomCW
Well, 5 dBv is almost a doubling of the noise level, but how much of that noise would be reproduced by a sub's limited frequency response is anyone's guess. For the small price difference, I'd go with the quieter one and then never look back.
Tom
Brian L
Jerome,
If you are just doing EQ of your subs, have you looked at the Behringer Feedback Destroyer? Thats the cheap EQ of choice among many HTF members.
I have not looked at the specs of the AS units, but I would wager that they are 1/3 octave at best, which is not fine enough to do an effective job with a sub.
And the Behringer is about $100 so you would be in the same ball park.
BGL
Jerome Grate
I thought about the Behringer, my problem was locating it locally for immediate hook up. I'll see if J and R has it.
Brian L
Surely there is a music store in Manhattan that carries Behringer. Perhaps Sam Ash or a Guitar Center type of place.
Most hi-fi oriented shops would probably NOT carrier it.
Good luck.
BGL
Sheqy
