Picking Center Channel Speaker
Discussion in 'Archived Threads 2001-2004' started by Eric_L, Dec 5, 2002.
  1. Eric_L
    Eric_L Screenwriter
    Nov 2, 2002
    1,994
    Ok, so I decide it's time for me to pick a center channel speaker. I go to my local CC, and had a VERY patient salesman plug in a half dozen center channels.
    Playing a variety of music I couldn't tell the $5 from the $250 speakers. And I'm SURE there's a difference. WE tried Polk, infinity, Pioneer, etc.
    What am I not listening to or for?
    FYI - my center channel will be in front of an 8' wide projection screen that is 5' off the floor. The L+R speakers are equal distance about 20' apart. That'd be 9-10 feet from the center channel each. I sit about 12 feet back from the wall. The room is 24x24 w vaulted ceilings.
    I want to replace my center channel speaker now because it was never designed to be a center channel. During movies I hear the sound coming from the speaker, instead of it seeming to come from the screen. I want one with a wider and taller soundstage.
    My rears are crap, but my L+R are nice Infinitys and my sub is a Velo 15. Yes, I'm buying this sys one set at a time.
  2. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    Which Infinity's? Go w/ the largest sub and look for one in which the voices sound natural and not like they are coming directly from the box. The larger subs do a good job w/ this. Make sure the drivers are close to the same size as you fronts if you can. Good luck.
  3. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    I'm guessing that the matching Infinity center is no longer made and your mains are older, but nice models. How much do you want to spend? Do you have a size requirement? There are lots of nice center channels out there.
    If you're going to replace the Infinity's w/ something else soon, then just get the center channel in that line. If not, then start looking at what's out there.
    You looked at speakers up to $250; here's one for $140:
    http://www.htdaudio.com/levthrecensp.html
    http://store3.yimg.com/I/htd_1714_2559115
  4. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Try to get a speaker that closely matches your main L/R mains. Most speaker lines have a center that is voiced to blend with the rest in the line. Ideally, all three speakers in the front should be identical. I can tell you three identical speakers sound amazing compared to a "Center" channel with a MTM (midrange-tweeter-midgrange) configuration.
  5. Eric_L
    Eric_L Screenwriter
    Nov 2, 2002
    1,994
    My fronts are only a month old, they are Infinity Entra One
    http://shop.store.yahoo.com/dirtchea...none2way6.html
    I'm quite pleased with the sound.
    I listened to the INF center; it was either one of these (i dont recall) Not sure which is matched to my fronts.
    Infinity ALPHACENTERBK: or Infiinity ENTRACENTRTWO
    http://www.circuitcity.com/frame1.js...Y+SPEAKER&qp=0
    My Velodyne 15" Sub is up to task. My rears are next to go after the center channel.
    Will the Infinity 'fill' the space between the fronts? I want to hear the sounds, not the speaker. The speaker I have now is very clearly the source of center audio. I want the sound source in the center to be more ambiguous.
    If that means something other than Infinity, so be it.
    When I listen to the speakers in the showroom I cannot distinguish one from the other. What should I listen for?
