Phono pre?
Discussion in 'AV Receivers' started by ChrisHeflen, Jan 12, 2005.
  1. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    I just found a place that is clearancing out a MMF 2.1 LE turntable and thought about getting it.
    I have the Anthem Avm20 and would need a phono pre ?
    How does this work and can you get an inexpensive one and still have it work good?
    What am I looking at for cables? Just standard rca's?
    Or is all this stupid?
  2. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    It's not stupid.
    You need a phono pre if your receiver/preamp doesn't have a dedicated "PHONO" input. www.partsexpress.com has one cheap, so does Radio Shack, either would be fine. Standard RCAs are all you need, and a ground wire.
  3. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    For the money, the NAD PP-2 is a very good little phono preamp and would match nicely with the MMF-2.1, IMO. You can find them new at just about any shop that sells turntables or on AudioGon.
    Radio Shack had a small, battery power phono pre that was pretty popular. It's called the "Little Rat" by most people, but I don't think RS sells it anymore.
  4. gregD
    gregD Second Unit
    Jan 16, 2003
    420
  5. Philip Hamm
    Jan 23, 1999
    6,873
    2
    waitaminute.....
    It is stuipd if you don't have any vinyl to begin with..... Spending this much on a new format with limited availility is quesionable.... Unless you scrounge at the Salvation Army or used vinyl stores or your basement....
    Vinyl is neato!
  6. ChrisHeflen
    Sep 9, 2002
    912
    I think what I am gonna do is go the pawn/shop garage sale route for a turntable and then see how far I get with it that way on the cheap.
    If I find that I'm liking it a lot then I'll pursue it on a bigger level.
    Thanks for the help guys
