Phono pre-amp grounding on HK520?
Discussion in 'Archived Threads 2001-2004' started by JohnSer, Dec 11, 2002.
  1. JohnSer
    JohnSer Stunt Coordinator
    Dec 4, 2002
    198
    I received the cheapo Radio Shack phono preamp today. Should be fine for the few times that vinyl gets played a year. Should the turntable ground wire go to the preamp case, and run another wire to the HK chassis?
    JohnS
  2. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    You should only have to run the ground to the phono stage.
  3. JohnSer
    Dec 4, 2002
    198
    Thanks, wired it up today, and all is fine.
    JohnS
