Phone Input
Discussion in 'AV Receivers' started by Andy Pressman, Mar 28, 2004.
  1. Andy Pressman
    Andy Pressman Auditioning
    Feb 13, 2002
    14
    When I bought my reciever, I never thought that I would need a phono input, but now i do. Can I just plug the turntable into my reciver using a normal rca jack, or is there a special adapter?
  2. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    Yes, you do need an adapter. $30-40 avaible at Circuit City, Radio Shack and others. I think it's called a phono plug amplifier or something like that. They will know what you need at the store. Remember to hook up the ground wire from the phono as well. Gene
  3. Andy Pressman
    Feb 13, 2002
    14
    What a rip off, considering it probaly costs less than a dollar to make. I'll probaly just hook up an old reviever and then output the signal though the rca jack.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    What’s needed is a phono pre-amp, because phono signals are much lower than other components. The trick to use an old receiver is a good one, they typically have phono pre-amps far superior to what you find in modern receivers.
    Wayne A. Pflughaupt
