Phillips DVDR985 Questions...
Discussion in 'Playback Devices' started by Dave Pobuda, Aug 15, 2003.
  1. Dave Pobuda
    Dave Pobuda Stunt Coordinator
    Dec 25, 1999
    82
    Well I just returned from a trip to Circuit City (was supposed to pick up CD-R's ONLY)I happened to wander by the DVD Recorders and they had the Phillips as a open box special for $289.00 ! How could I refuse ?
    One question I have though is on the rear panel there are component in and component out connections. Was wondering if it will pass through the component signal ? I am hoping to hook up the PS2 to the component in. does anyone know if this will work ? Also I have read some post's at another forum about needing a firmware update?
    Any input will be appreciated.
    TIA
    Dave
  2. Phil Tomaskovic
    Phil Tomaskovic Supporting Actor
    May 8, 1999
    751
    3
    Probably only if you have it powered on and choose the component in as the input (just like if you ar dubbing from 1 vcr to another). It won't pass through powered off like an antenna coax cable.
