Philips "Mirror" Plasma (1 Viewer)
Jason Caudill
Has anyone seen/ heard of a new HDTV plasma display by Philips (I think) that when turned off works as a mirror? I have heard from two people that this is on its way out. One of them saw it in a Home and Garden show in Charleston, SC the other is a dealer who saw it in some of his literature. Neither knew too much about it. I am curious about how it works and any other info someone might have. Thanks, Jason
Parker Clack
Schizophrenic Man
Kansas City, MO
Parker
Jason:
Interesting to say the least. I haven't seen or heard of one of these units but it would be cool.
I have always thought that having a Plasma that had changing pictures of your favorite artwork would be cool too.
Parker
Kevin P
It probably has a semi-transparent mirror in front of the plasma screen. If this is the case, the contrast/brightness will be subpar compared to other plasmas, and you'll be able to see yourself watching TV. :)
You can do that now, just hook a computer up to your plasma and run a screen saver.
KJP
Parker Clack
Schizophrenic Man
Kansas City, MO
Parker
Kevin:
Yes I realize you can hook up your PC to do that I just think it would be cool where you could put a CDR or similar into the side of the plasma and have it rotate a few select pictures around for you.
Parker
BradJudy
I believe you can do this on the Sony XBR plasmas with the use of a MemoryStick card.
tarikulkhain
