phase question...
Discussion in 'Archived Threads 2001-2004' started by Jason Wilcox, Aug 29, 2002.
  1. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    ok so i've got a little 2.1 system hooked up to my computer. but, the sub is out of phase with the bookshelf speakers. unfortunately the sub also lacks a phase switch and i don't feel like opening my sub up to switch the wires. so, i just switched the phase on both my bookshelf speakers. problem solved. but, i keep hearing about "absolute phase"...
    does anyone hear a difference when they switch the polarity of both their main speakers? should i? (i don't)
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    32
    Katy, TX
    Wayne
    Jason,
    “Phase” and “polarity” are not the same thing. “Phase” is time-alignment, “polarity” is electrical (which would include speaker-level connections).
    “Absolute phase” means all the voice coils in a speaker with multiple drivers are physically (and thus time) aligned. Absolute phase is difficult to achieve in a sat-sub system unless there is a phase control on the sub, or a digital delay in-line somewhere. Lacking that, the only way to achieve absolute phase is to make sure the sats and sub are equidistant from the listener.
  3. Jason Wilcox
    Feb 21, 2002
    652
    ok thanks......i knew the speakers were out of phase with the sub because when i switched the sub on...frequencies around the crossover point went down about 8db.
    so just to clarify...it's OK if i switched the polarity (+ on receiver to negative on the speaker) of both mains to match the phase of the sub right?
  4. Jason Wilcox
    Feb 21, 2002
    652
    right?
  5. Jason Wilcox
    Feb 21, 2002
    652
    i've got the + on the receiver going to negative on the speakers and - on the receiver going to + on the speakers in order to match the phase of the sub. is this ok?
  6. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
  7. Jason Wilcox
    Feb 21, 2002
    652
    ah ok......i mean it's obvious that something isn't right when i switch the polarity in one speaker....but when i switch both it sounds normal
  8. Saurav
    Feb 15, 2001
    2,174
  9. Jason Wilcox
    Feb 21, 2002
    652
    thank you! that was the explanation i was lookin for
  10. Saurav
    Feb 15, 2001
    2,174
    You're welcome. Glad to be of help.
