- Aug 23, 1998
This isn't correct. The premasters may have been the same but you can not use full range masters for LP production, they have to be processed to the RIAA curves to create the mother (stamping master). Every release has to be mastered for the medium it is intended for, so while the source mixes may be the same, the production master is different. Even the original CDs went through a mastering process, and there was EQ and limiting applied, it's just that in the old days the A&R departments hadn't been exposed to the extremely limited dynamic range made possible by look ahead limiters, and therefore the older CDs had more digital headroom, and as a result, sounded better in that regard because they aren't clipping the D/A stage. The problem back then was that the A/D chain was weak due to poor filter design, which caused its own problems.
