ChrisA
- Nov 25, 1999
I agree that this petition could be made into a "STATE OF AFFAIRS" general petition discussing several issues such as edge enhancement, OAR, etc....
By the way, does anybody know the difference in licensing fees between DD, DTS, and MLP? I was hoping MLP decoding would be universal in all DVD players by now. Certainly, any new HD-DVD format would HAVE to include DVD-A support, so using MLP would be a huge quality increase... it would forever end the lossly compression debate with an unquestionably superior MLP lossess compression.
Let's say you have 30 mbps bandwidth to play with. You could have 20 mbps video and 10 mbps 24/96 MLP fitting just fine together. In any case, MLP can also be run at 20/96 or 20/48 for that matter. As much as I hate the politics, you'd likely see suport of MLP as the next generation compression algorithm because it will already be a mandatory part of optical players. Dolby already has their hands in MLP, so I'd say the future is bright for use of MLP. DD and DTS playback will still be there for backward compatability *and* they can be utilized for higher compresion of ACCESSORY TRACKS AND OTHER SECONDARY LANGUAGES.
I'd like to discourage any talk about DSD in movies and focus on MLP. Without starting a debate on MLP vs DSD, it is quite apparent to me that any talk about using 24/192 MLP or DSD for a movie format is not constructive at this point in time. Perhaps in the year 2025 we can think about such issues. Any talk beyond MLP running at 24/96 for movies would be over 10mbps for the main audio track and at that point, you'd want to put more toward video anyway. Regardless, MLP at 20/48, 20/96, 24/96 is the answer for movies I believe. DTS running at full bitrate would be my second choice. DD and DTS running at half rate as in current DVD is no longer acceptable for an HD-DVD medium other than secondary tracks, backward compatability, commentary tracks, alternative languages.
I find it interesting that Dolby Digital hasn't developed a 'less harsh' algorithm to compete with DTS. The efficiency of DD is not the issue. DD should be able to design a lossy compression algorithm that could run in the 2 mbps range that would be much more faithful to the master than the current DD format.
The point is that current DVD total bandwidth of 10 mbps is not acceptable for an HD-DVD format.
