Walt H
- Aug 5, 2000
On the RX-V1400 the PEQ and GEQ settings are independent setups. Since you can't change the PEQ settings after the Auto Setup, can you switch between the PEQ and GEQ (Manual settings) without interfering with the individual setting of the other?
Example: After running Auto Setup of the PEQ if you decided to do a GEQ (Manual GEQ settings), can you switch back and forth by selecting PEQ or GEQ in the Graphic Equalizer section while keeping each Equalizers Settings intact?
