Peerless XLS 12 vs. Adire Shiva 12
Discussion in 'Archived Threads 2001-2004' started by Greg P, Aug 29, 2001.
  1. Greg P
    Greg P Stunt Coordinator
    Jan 7, 2001
    92
    I have been thinking about building a sub for a while and currently was looking at dual 12's instead of the Tempest I originally though about. The Peerless interested me a lot. I cant find exact measurements, but fromthe passive radiator, I gather it has a one way xmax of 24mm. I believ the Shivas is 16mm? I saw the peerless at madisound for $145 I believe, and from the specs it looks like it would require a smaller box than the shiva to get a low Q. Im planning on a Q between .577 and .60. I am having a hard time understanding the spec sheet at the peerless sight. I would like to use 2 of those peerless 12s if I could keep the box reasonable small. Could some one tell me more about this driver? Also if I am correct about the Xmax, price etc.?
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The Peerless (non-autosound) XLS 12 has an Xmax of 12.5mm, Vas of 136.8L and a Fs of 17.8Hz. And they cost $145ea from Madisound
    The Shiva has an Xmax of 15.1, Vas of 144L rated by Adire, and 14.9mm, Vas of 136.6L from DUMAX, with a Fs of 22Hz or 21.61Hz accordingly. And they cost $115ea from Adire.
    So the Peerless is 25% more expensive, and uses roughly the same sized box.
