Michael Cawcutt
- Jan 14, 2004
Hello all!
htf.com has been great for me so far, have another quick question to be answered. My dvd player (Panasonic DVD-S35) has the option for PCM Down Conversion. It has the ability to convert the default output sampling frequency of 96kHz/88.2kHz to 48kHz/44.1kHz. My new Onkyo 601 is on it's way as we speak, and looking at the details and specs of the receiver, I am not "educated" enough to know if this receiever is capable of processing the 48kHz/44.1kHz frequency.
What does this conversion allow or do? When the sampling rate changes does this improve sound quality? Below are the specs for the Onkyo TX-SR601 from crutchfield. I didn't get it from crutchfield but here are the specs for people who will be able to answer my question
Key Features:
85 watts x 6 into 8 ohms (20-20,000 Hz) at 0.08% THD
Dolby Digital EX, DTS-ES and Pro Logic II decoding
DTS Neo:6 modes
dual 32-bit processors
Wide Range Amplifier Technology
dual-room/dual-source audio (powered and preamp stereo output for 2nd room)
composite-to-S-video conversion
192kHz/24-bit DACs
learning/multibrand remote
CinemaFILTER (adjusts tonal characteristics of soundtracks recorded for movie theaters for a home theater setting)
component video switching: 2 in, 1 out (50MHz bandwidth)
digital inputs: 3 optical (including 1 front-panel), 1 coaxial
optical digital output
2 audio, 5 A/V (including 5 S-video, 1 front-panel, and one 5.1-channel) inputs
on-screen display (requires TV with direct video input)
40 AM/FM presets
banana plug-compatible binding posts for all speakers
aluminum front panel
oversized power transformer, filter capacitors and heat sinks
no phono input
17-1/8"W x 6-15/16"H x 17-9/16"D
warranty: 2 years
Key Features:
DTS Neo:6 modes
192kHz/24-bit DACs
40 AM/FM presets
no phono input
warranty: 2 years
