zach^F
- May 24, 2003
I have a panny RP56 and messing around with the audio options. I am using a optical out connection to my Denon 1802. I have had the PCM down conversion set to "NO" for like the past 2yrs and I was re-reading (uh really reading the manual...) the instructions which say set PCM down conversion to "Yes" for digital connections with a receiver that has a DD decoder??? It also says that it is because of copyright protection and material in 96Khz will have no sound, so it must be down converted to 48Khz. Well, I have never had any trouble with sound and don't know why I would want to use the lower quality signal. It does say that if my receiver is 96khz LPCM compatible it will play the high quality sound as long as it is not copyrighted? What should I have this set at, am I off track that down converting decreases the quality of audio. Please shed some light on this for me
Zach
Zach
