PC Mod Help
Discussion in 'Archived Threads 2001-2004' started by Jeff Braddock, Mar 22, 2002.
  1. Jeff Braddock
    Jeff Braddock Second Unit
    Jan 26, 2002
    306
    I have never moded a case befoe, but I am thinking about trying. What I would like to do is find an old beast of a computer at a yard sale or auction or something like that. If it doesn't work, or well, maybe I'll try to get it going or something...but my question.... Without buying a window kit, how do you attatch the plexiglass to the case? Is there somekind of weather stripping or something? Also, what is the best way to cut out the window hole, a Dremel type tool? Thanks for all your help in advance.
  2. Richard_s
    Richard_s Second Unit
    Nov 25, 2000
    267
    You can use a standard sabre saw with a fine tooth metal cutting blade. just cut slowly and dont rush it. Drill a hole in opposite corners to fit the blade. A dremel might work I just never used mine for this. I cut a whole as I stated for a ventilation fan.
    Use double sided adhesive FOAM tape. This is about 1/16 inch thick and found at most hardware stores or a store like Home depot. This stuff hold reasonably well at first but once the adhesive "air" cures you probably will have to break the plexiglass to get it off. If you use the thin double sided tape it wont hold. Also clean the plexi suface and the metal suface with alcohol first.
  3. Jeff Braddock
    Jan 26, 2002
    306
    Richard, when you say saber saw, are you referring to a jigsaw?
    I am thinking I will probably mount the glass behind the cutout as it will be an irregular shape. Will glass like from a windshield or car window work? If so, I might try to get an old piece or two from a body shop here in town.
  4. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Jeff,
    Yes a Saber Saw and a Jig Saw are one in the same. A Scroll Saw is similar to
    Both the Saber and Jig the main difference being that a Scroll Saw has a table
    Mounted to it and you have to either cut into the piece or remove the blade
    To get it inside the piece for internal cuts.
    As far as using actual “glass” that would be unadvisable. Plexiglas, Lucite or
    Lexan are the plastics of choice and the only materials I would recommend. Real
    Glass is not only hard if not impossible to cut in “odd” shapes but it is also as you
    Know, prone to breakage. Plexi, Lucite and Lexan are shatter resistant materials
    And they are simple to cut with a Dremel or Jig/Saber Saw.
  5. Jeff Braddock
    Jan 26, 2002
    306
    Brett,
    As I said, I would probably be mounting the plexi or whatever behind the cutout, not directly in it so cutting it wouldn't really be that important. I had just thought I could probably get a piece of glass from the body shop for free and I'm all about free stuff. [​IMG] I don't know, I might just do a better paint job and no cutting this time. I just don't know. Oh shoot! Brett, I'm sorry I haven't emailed you that article about the heat pipes yet. There are a couple of reasons 1. I scanned jpegs of the pages and since there are 4 or 5 pages, the attatchment is a pretty big one. 2. I have a dialup, and was going to send them from school, but haven't got to it, 3. I have been so busy with midterms and work that I haven't had a chance. I will try to get them sent to you sometime this week. Sorry.
  6. Brett DiMichele
    Sep 30, 2001
    3,181
    Jeff,
    No rush on the article..
    I did order the new CoolerMaster Heat Pipe for the Socket
    478 Pentium 4 from Digitron.com no one else would custom
    order anything for me! Should be here in 7-10 days.
    I still would stick with Plexi,Lexan,Lucite. Honestly the
    stuff is cheap, you don't need anything more than 1/8 of
    an inch thick and that thickness is dirt cheap. I bought
    a piece of Lucite 1/8" thick for my 61" RPTV and that's one
    hell of a HUGE piece of Lucite and it was only $40.00!
    Your looking at maybe $10.00-$15.00 for the piece you will
    need.
  7. Jeff Braddock
    Jan 26, 2002
    306
    Well, what I am considering doing is this: you remember the Thundercats? well, I would like to cut out the logo, leaving the head sitcking out into the hole, painting the whole thing black, and having red lighting behind the window. I think it would look cool in the light,but especially in the dark. Either that, or doing the superman symbol. Theses are just thoughts. I don't really have any money to sink into the project (I'm a poor college student, blah blah blah). I am open to any ideas, but first off I need to find an old beast of a computer...
  8. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    a lot of people just use a dremel for their cutting needs. just get a whole bunch of cutting blades and go to it. of course i assume most people do that because they dont have the proper equipment, so if you do have the equipment, then i say use the jigsaw, but if you dont, the dremel will work with patience...
  9. Brett DiMichele
    Sep 30, 2001
    3,181
    David,
    Actually the Dremel is more appropriate cutting equipement
    than a Jigsaw IMHO. The dremel affords you a much better
    sense of control for doing precision cuts. The problem is
    that it may be very difficult to cut through steel with a
    dremel. You can pick up 12 or so Fiberous Cutoff Wheels for
    the dremel and give them a shot (it's what I use for cutting
    metal)
    Lucky for me, my side pannel is ABS Plastic and cutting it
    will be simple!
  10. Jeff Braddock
    Jan 26, 2002
    306
    Well, unfortunatley it may be a moot point because I don't have an old junker computer to experiment on. I couldn't decide between the Dremel and the jigsaw (if I even did it) for a couple of reasons. 1. with a jigsaw I would imagine there would be a lot of vibration. This could cause some difficulties when cutting the round shape, etc. On the other hand, I believe it has a guide that would allow me to cut a percise circle. 2. the Dremel does not have this, but since the part the guide would be attatched to would be getting cut out it may be pointless to even consider this.
    I may not even do it, I don't know. I thought it would be a little easier to find an old computer, even like a 486 or a Pentium 133 or something. *sigh* Oh well.
  11. David_Stein
    Feb 13, 2002
    422
    i suggest buying a case, they really arent all that expensive. just something to tool around with, and if you make something you like, you can always transfer your main system into the new case.
    try newegg.com, i highly reccomend them
  12. Jeff Braddock
    Jan 26, 2002
    306
    David,
    I considered doing that, but I would like to get another system because I am wanting to try my hand at overclocking and stuff and I don't really want to risk messing up an already working computer. I know it sounds like I am wussing out, but chance favors the prepared mind.
  13. David_Stein
    Feb 13, 2002
    422
    i dont know how much overclocking you are going to be able to do with a junker system though...
  14. Jeff Braddock
    Jan 26, 2002
    306
    Well, any would be better than none ya know [​IMG] I think my main thing is I just want something to tinker around with.
  15. David_Stein
    Feb 13, 2002
    422
    probably the cheapest and best "junker" system to play with would feature the a celeron 300a. they used to routinely overclock to 450 without a problem. i bet they are cheap now if you can find someone selling one...
  16. John Thomas
    John Thomas Cinematographer
    Mar 23, 2000
    2,633
    I've run across the newest fad in case modding. It's so easy to do, it's funny. Check out this link: LINK
  17. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    i have a old case which i was going to mod but never got around to. it's a pizza box (horzontal config)
    If you pay for actual shipping it's yours
    Grant
  18. Brett DiMichele
    Sep 30, 2001
    3,181
    John,
    Paint that sucker gloss brown and you'd have an instant TURD! [​IMG]
  19. Jeff Braddock
    Jan 26, 2002
    306
    An update...yipee! I think I may have hit a jackpot. My dad's g/f works at a school and when I mentioned that I was looking for a computer, she said the school she works at was getting ready to throw a bunch out. She said she would get as many for me as she could. She asked if I wanted a PC or an Apple...so I'm thinking the eqivilent of an Apple IIe, so hopefully it/they will have a little more horsepower than that.
    John,
    As tempting as that mod was....I think I will pass [​IMG]
    Grant,
    Thanks for the offer. I am looking for a tower case if I can find one, and with the possibility of getting a few comps for free...well, I think I'll see what happens there first.
