PC Booting problem / ZoneAlarm
Discussion in 'Computers' started by Tony_La, Jul 15, 2004.
  1. Tony_La
    Tony_La Stunt Coordinator
    May 23, 2002
    59
    I received the following on my home PC last night:
    "vsmon.exe - Bad Image
    The application or DLL C:WINNTsystem32VSUTIL.dll is not a valid Windows Image. Please check this against your installation diskette."
    It wouldn't boot with the Admin profile, but a temp one.
    The only thing I can find on this is that it is related to ZoneLabs ZoneAlarm in some way.
    Windows 2000
    ZoneAlarm (free version)
    Can anyone help?
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    vsmon is indeed apart of zonealarm. You've a couple of solutions available depending upon your skill level with a computer.
    easy solution - reinstall zonealarm (if you can't access windows, go into safe mode)
    difficult solution - open up regedit and remove all references to vsmon.exe and other zonealarm files.
