pb12-isd comparable to b&w
Discussion in 'Speakers' started by Dennis-L, Mar 8, 2005.
  1. Dennis-L
    Dennis-L Auditioning
    Mar 2, 2005
    6
    Anyways i was wondering if a pb12-isd is comparable to the B&W 600. As i loved the B&W low, deep bass.
    Only reason as i am considering trying out the svs is $$ budget. So any helpful comments/opinions on how the pb12-isd compares to the B&W is appreciated.
    Btw speakers are monitor 7's and cc-370
  2. JasonCI
    JasonCI Stunt Coordinator
    Dec 29, 2004
    59
    If you love low, deep bass you've love the PB12. In this respect there's no comparison IMO. The cylinder equivalent model from SVS may even be more to your liking.
  3. Eric Ha
    Eric Ha Stunt Coordinator
    Sep 27, 2004
    146
    Honestly, the SVS should crush the B&W. Look at the stats.
    12" driver vs. 10" driver
    320 watt amp vs. 150w amp
    -3db @ 20hz vs. -3db @ 26hz
    18" x 21" x 20" vs. 14.5" x 14.5" x 18"
    78 lb. vs. 43 lb.
    The smaller SVS PB-10ISD should whoop the B&W also if you're on a budget.
  4. Dan Halchak
    Dan Halchak Stunt Coordinator
    Jul 17, 2003
    195
    The SVS WILL crush the B&W.
    My PC+ 20-39 is very compareable to the N800 sub... So the PB12-ISD would easily play lower, better, and not have the "boominess" of the B&W.
    I went through the B&W 600, 650, 675, 800, and 850 before I settled on the SVS...and it by far has impressed me far more (for the price) than any of the B&W subs. I love my B&Ws, don't get me wrong, I want my 802Ds (if only I could afford them)!!!!! But their subs leave something to be desired.
    I agree with Eric Ha as well, the PB10-ISD would definitely give the SVS 600 a beatdown. The B&W 600 sticks out like a sore thumb, it's more heard than felt. It does not integrate seemlessly into the soundstage. My friend's B&W 600 I can point it out every time exactly where the sub is. I had my SVS over there, you couldn't tell if it was on at all, it seemed like the mains were play just that incredibly low... [​IMG] That's how I like it.
  5. Eric Ha
    Sep 27, 2004
    146
    Dan, just makes you wonder what those SV speakers will be like, don't it? [​IMG]
