Password Protection?
Discussion in 'Computers' started by Mark Shannon, Jul 21, 2003.
  1. Mark Shannon
    Mark Shannon Screenwriter
    May 27, 2002
    1,991
    Is it possible to password protect a file or (hopefully) a folder, without the use of an outside program (using only the OS)? If it helps, I'm using Windows ME...
    Thanks in advance...
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    The easiest way is to just put the file/folder where no one would expect it to be, like in a file folder for a game. You can even rename it to something that would make it look like it is part of the program.
    You can change the file extension too, and just change it back when you want to go into it. For example, you can change a file called password.exe file to a rungame.brg, or whatever you want to.
    Glenn
  3. Greg Rakaska
    Greg Rakaska Stunt Coordinator
    May 16, 1999
    111
    Not w/o a third party program with ME. If it is a Word or Excel doc, then You can lock it, but the net is full of cracks for those two programs.
    You can get a free copy of PGP that can encrypt and protect files at http://www.pgp.com/products/freeware.html.
    This may be more than you want/need, but I can guarantee it is totally secure, and the price is right!
  4. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    Not with ME or any of the 9x series. The only way to get folder-level security is to go with an NT-based system like 2000 or (ugh) XP.
    If I recall correctly you can hide a folder (right click -> Properties -> Hidden); however, that will only work if the "Show hidden files and directories" is turned off in Windows Explorer.
