Austin Shoemake
- Dec 22, 2001
I was wondering whether it is neccesary to build a crossover for my sub if it is run through an external amp? It will be routed through the LFE output of my reciever to an external amp and then to the sub. I am currently running the sub with a plate amp, but the amp is clipping at moderate levels and the power supply fuse has blown. I think I can get less distortion and better overall output with my external amp which is the diy Leach amp. The sub is a 142.5L ported cabinet tuned to 18.1Hz. This is the EBS alignment from adire audio with a shiva driver. Please let me know if you have suggestions for a crossover or whether you think a crossover is unneccesary. Thanks in advance,
Austin
Austin
