Passive radiator vs. Vented
Discussion in 'Home Theater Projects' started by Jonathan T, Jan 16, 2004.
  1. Jonathan T
    Jonathan T Second Unit
    Nov 6, 2002
    360
    I modeled 1 AV-15 with both passive radiators and as a vented box. At 5 cubic feed, the output is almost identical. But, what's the difference SQ wise?
    O, and do you think a 5 cubic foot sealed Av-15 would be sufficient for most movie sound tracks (assuming I don't want to break windows)?
  2. MattD
    MattD Stunt Coordinator
    Feb 29, 2000
    166
    How big is your room? I have an AV12 in a 14'x20' room and it is more than enough to rattle pictures off the wall.
  3. Eric Eash
    Eric Eash Second Unit
    Aug 3, 2003
    367
    there shouldn't be too much difference in SQ. the PR sub might have a little bit better transient response. mainly, PR are great for small boxes as a low tuned vented box can require more room for a vent than available, and most people don't want their port sticking a foot out of their enclosure. if you're box is big enough, vented is waaaay cheaper.
    eric
  4. Rob Formica
    Rob Formica Stunt Coordinator
    Feb 20, 2003
    225
    PR's also eliminate the risk of any port noise... so they do have a slight SQ advantage. But then again, as already mentioned, the main benefit is providing low tuning in a small enclosure.
    Rob
  5. Jonathan T
    Nov 6, 2002
    360
    The room I would be using is about 18X12. It's open on one side. I was thinking of using 2 subs because I read a paper somewhere that said 2 subs or more can can help nullify "bad" nodes and excite the "good" ones.
  6. Jonathan T
    Nov 6, 2002
    360
    Thanks for the info on PRs. I was really just curious as to each would sound. I don't have money for 4 100 dollar PRs for 2 AV-15 subs. So, it's gonna be either sealed or ported. And it'll probably be sealed, as this will be a 2 channel system. I don't have money for a multichannel theater right now.
  7. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    why not ported, you need the small enclosure?
  8. Jonathan T
    Nov 6, 2002
    360
    Well, no, but sealed enclosures are condusive to "tighter" bass, correct?
    It's been a while since I've discussed or thought about DIY audio
  9. AllanRW
    AllanRW Second Unit
    Nov 30, 2001
    342
    I did a AV15 in a 24" cube for Craig WoodhallCraigs ported AV15
    As far as I know he is very happy with it.
    Al
  10. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    yip, love your work Al! thanks again.
  11. David_P
    David_P Stunt Coordinator
    Dec 12, 2003
    149
    Craig... I sent you a PM. Please check.
    thanks.
    Dave P
